Inventor General
Member
Message 1 of 6 (405 Views)
Accepted Solution
Beam/colmn Calculotor: Changing the angle of a distributed load
405 Views, 5 Replies
08-20-2012 09:38 AM
I am using beam/column calculator in the frame generator in inventor 2010 suite.
I have a beam being used for a flight of stairs it is positioned 40 deg above the 'floor' or my xy plane in my assembly.
I want to place a distributed load acting as if there were several people stading on the stairs at one time so in the direction of the z axis of my assembly.
The problem I am having is I try to change the angle of the distributed load but it only allows me to change the x and y components of the load. You can see this in the screenshots i took.
Is there a way I can:
a) change the angle of the laod in the Z directions
or
b) change the cordinates in beam itself so the x axis is along the length of the beam instead of the z axis.
I have tried adding a UCS to the beam part but it still wants to choose the length of the beam as the z axis.
Any help would be greatly appreciated.
Matt
*Expert Elite*
Message 2 of 6 (379 Views)
Re: Beam/colmn Calculotor: Changing the angle of a distributed load
08-20-2012 01:52 PM in reply to: vogelzmr
I'm not sure what all of the options are in the beam calculator, but you could do this by splitting your load into a Y component and an axial load component (Z component).  So in effect, you will have two loads applied.  One for the vertical Y component of the total load, and an axial load for the Z component.  Does that make sense?
*Expert Elite*
blair
Message 3 of 6 (376 Views)
08-20-2012 02:09 PM in reply to: vogelzmr
Select/Check the Vector box in the Load dialogue box. You can then enter in your load vectors, or create a work axis and use it for load direction. I believe you can even use a Work-Axis to define the load direction (still need to "Check") the vector box.
Sorry, I was thinking of either analysis in model or frame-gen.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Member
Message 4 of 6 (347 Views)
08-21-2012 10:06 AM in reply to: blair
There is no vector box to 'check' i think that is a feature of the stress analysis found in the 2010 pro version, which i unfortunately do not have. I am using the beam/column calculator found in the frame generator feature of the 2010 suite version.
Member
Message 5 of 6 (345 Views)
08-21-2012 10:08 AM in reply to: cwhetten
This will work, i just was hoping to avoid breaking up my applied load into axial and shearing loads, i know that is lazy of me, thanks for the help!
Matt
*Expert Elite*
jdkriek
Message 6 of 6 (332 Views)
08-21-2012 01:31 PM in reply to: vogelzmr
Good information, thanks for sharing.
Jonathan D. Kriek
Autodesk Inventor Certified Expert
Microsoft Certified Application Developer
_____________________________________________________
Did I help you? Please choose Accept as Solution or Kudos below
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
