Inventor Forum
Beam/colmn Calculotor: Changing the angle of a distributed load
5 REPLIES 5
vogelzmr
876 Views, 5 Replies
I am using beam/column calculator in the frame generator in inventor 2010 suite.
I have a beam being used for a flight of stairs it is positioned 40 deg above the 'floor' or my xy plane in my assembly.
I want to place a distributed load acting as if there were several people stading on the stairs at one time so in the direction of the z axis of my assembly.
The problem I am having is I try to change the angle of the distributed load but it only allows me to change the x and y components of the load. You can see this in the screenshots i took.
Is there a way I can:
a) change the angle of the laod in the Z directions
or
b) change the cordinates in beam itself so the x axis is along the length of the beam instead of the z axis.
I have tried adding a UCS to the beam part but it still wants to choose the length of the beam as the z axis.
Any help would be greatly appreciated.
Matt
5 REPLIES 5
cwhetten
in reply to: vogelzmr
I'm not sure what all of the options are in the beam calculator, but you could do this by splitting your load into a Y component and an axial load component (Z component).  So in effect, you will have two loads applied.  One for the vertical Y component of the total load, and an axial load for the Z component.  Does that make sense?
blair
Select/Check the Vector box in the Load dialogue box. You can then enter in your load vectors, or create a work axis and use it for load direction. I believe you can even use a Work-Axis to define the load direction (still need to "Check") the vector box.
Sorry, I was thinking of either analysis in model or frame-gen.
Delta Tau Chi ΔΤΧ
vogelzmr
in reply to: blair
There is no vector box to 'check' i think that is a feature of the stress analysis found in the 2010 pro version, which i unfortunately do not have. I am using the beam/column calculator found in the frame generator feature of the 2010 suite version.
vogelzmr
in reply to: cwhetten
This will work, i just was hoping to avoid breaking up my applied load into axial and shearing loads, i know that is lazy of me, thanks for the help!
Matt
jdkriek
Good information, thanks for sharing.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
