Inventor General
karthur1
Message 1 of 4 (319 Views)
Beam and Column Calculator gives wrong values
319 Views, 3 Replies
04-16-2013 01:38 PM
Having trouble with the Beam and column calculator again.  I used the "I-Section" and entered the values.  At first I entered (b) as 8in and (B) as 8in and got the correct values. My section changed to (b)=6in and everything else stayed the same.  Inventor now reports the incorrect value for the area and moment of I.
Here is what I entered.
Manual calculations shows this should be 30in^2.... not 29.
TOTALY, NO confidence in the Beam and Column calculator at this point!!
blair
Message 2 of 4 (302 Views)
Re: Beam and Column Calculator gives wrong values
04-16-2013 02:55 PM in reply to: karthur1
You're welcome to a old spread sheet that I did up back in the hand calculation days.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
karthur1
Message 3 of 4 (280 Views)
04-17-2013 05:37 AM in reply to: blair
Blair,
I have a speadsheet that does these calculations.  I was just double checking what I have against Inventor.  At least yours and my spreadsheets agree with each other...:smileyhappy:
I checked what Inventor 2014 Beam and column calculator reports and it shows the correct values also.  Guess they already knew about this error and fixed it.
Have a great day!!!
Kirk
blair
Message 4 of 4 (267 Views)
04-17-2013 08:22 AM in reply to: karthur1
There you go: the I'm OK and you're OK syndrome.
Win7-64
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
