Inventor Forum
Beam Sizes
2 REPLIES 2
jtwalker1
395 Views, 2 Replies
Beam Sizes
I just decided to try one of our projects in inventor that uses beams and channels.  After building the part, I was detailing out the parts and the shop noticed that the copes on the beams are not correct.  After measuring the beams in inventor, I notice that the web and flange thicknesses on one of the main beams is pretty far off.  Is this common.
example.  AISC shows a W12x72 web as 7/16" inventor has .55"  the flange as 11/16", inventor has .9" these are both off way too much. Height shows 12 1/4" and inventor has 12.710  This is not going to work if all the beams are off this much.
James
 Oh sorry, I forgot, this is using Inventor 2013.
2 REPLIES 2
graemev
in reply to: jtwalker1
My copy is generating exactly as it should.  ANSI W12x72.  Are you inserting this exact one?
jtwalker1
This is strange, I just inserted a new one and it comes up okay.
I attached a pdf of both, notice they both say W12 x72
Not sure what is going on with this.
