Does translating the assembly file that way result in individual translated files? is there any way to select the output for multiple files all at once or do they have to be selected individually? I have hundreds of files that I have to translate out for other systems.
I might do a Pack-and-Go to get out the files I need if they belong to a specific assembly. Get them to a separate directory with a Project file. Then run the Task Scheduler for that folder/project.
I see, the "Folder" choice doesn't allow a destination directory, hence the Pack and go. Makes sense. Ill try it ASAP and let you know.
