Inventor Forum
Batch "Save as" dwg
4 REPLIES 4
359 Views, 4 Replies
Batch "Save as" dwg
I have about 100 idw files that my customer wants converted to dwg format.
Is there a batch program or utility that will do this? I thought that I had
seen something on this in the past, but I could not find it.
Will the iBatchPrint on Cbliss.com do it?
Kirk
Dell 4550
WinXP Pro
P4, 2.8 Ghz, 1G
Quadro 900 XGL (pny)
nVidia v6.13.10.4072
1280x1024, 32 bit
4 REPLIES 4
Kirk,
You seen it on Kent's site.
http://www.mymcad.com/kwik/iCode/iBatchRun/ibatchrun.htm
QBZ
and Acesulfame-Potassium>
"Kirk A." wrote in message
news:0F106367C8436264BD68DB89E7B6D2A4@in.WebX.maYIadrTaRb...
had
I have a iBatchRun utility on my site. The saveas dwg macro on the page could use some
work, but it might do what you need. http://www.mymcad.com/KWiK/mcad.htm go to the
iCode page, then the iBatchRun link.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
> Kirk
> Dell 4550
> WinXP Pro
> P4, 2.8 Ghz, 1G
> 1280x1024, 32 bit
That works.
"Quinn Zander" wrote in message
news:29F98C96662F9932508DE1BC1C5FA6B6@in.WebX.maYIadrTaRb...
> Kirk,
> QBZ
> Phenylalanine,
format.
> had
Actually the macro works fairly well. I was having a bit of problems between inches and millimeters but found that my problem was with my Inventor templates. Once I straighten that out everything works fine or at least as well as doing it manually. Just remember to do one manually to set up the “dwgconfig” file before running the macro.
Ken
kdale@kadway.com
