Inventor Forum
Balloon Grab Handles
4 REPLIES 4
468 Views, 4 Replies
Hey I am working in a .idw and need to move around my balloons. There seems to be a small grab handle on each balloon. Is there any way to make this a bit larger. It takes a few clicks of the mouse to actually grab it and move it.
Tags (3)
4 REPLIES 4
Cadmanto
Chris,
What I do is when I hover over the balloon I wait until I get the square type symbol then select it.
This always works for me.
As far as a setting to enlarge the pickbox?  Don't know of one.  That might be something to do with your screen resolution setting.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
Ok, I see. Thanks for the respones!
andrewiv
You can get the grab handles to show up larger.  Go into Application Options and on the General tab there is a setting for Annotation Scale.  Simply mak this number as large as you want to get the handles larger.  This will also make a few other things larger, like dimensions in a sketch.
Andrew In’t Veld
Designer
thank you!
