I want to make sure that this will work before I go through the setup.
Available Equipment:
1 Lab (20 stations) with Autodesk software installed
1 Lab (20 staitons) with no Autodesk software installed
1 Windows 2008 server
I would like to use both labs for rendering and the server to manage the jobs. I know that the second lab will need backbruner installed and I assume which ever autodesk software that I am rendering from. Correct?
For the server, I know the service that needs to be installed and set to automatically run for rendering node and that is fine. If I want the server to manage the jobs is there another service that I need to have isntalled and running? A user will not be logged into the server when jobs are running so the Manager needs to be running in teh background.
Currntly we have a station that a user logs into and opened the Manager software and he will submit the job. I want to be able to have it setup that the user can then log out and have the job continue to render.
Any help I can get would be much appreciated.
no Backburner is only used by 3ds max and some other M&E products this is not used by inventor which is where your posting this
DarrenP
you need to post this on the correct M&E product here: http://forums.autodesk.com/t5/Autodesk-Media-and-Entertainment/ct-p/Media_and_Entertainment
DarrenP
Thank you for the quick response. Truthfully, I could not find the 3ds Max area so I jus threw it in here hoping for a response.
The Area discussion group you want is here: http://forums.autodesk.com/t5/Autodesk-3ds-Max/ct-p/area-c1
This is the latest installation guide:
http://images.autodesk.com/adsk/files/backburner_install_guide_for_3ds_max.pdf
Your Backburner Manager software can be installed as a service on the Windows Server so there is no need to have anyone logged in to run it. You would also install the Backburner Server software on all the workstations in both labs. Install Server as a service too so it's available all the time. The queue Monitor can be run from any workstation - all you do is connect it to the manager to see/manage all jobs. From the monitor, you can even specify times of the day where certain workstations are unavailable - probably during class time!
Once a job is submitted to the manager, users can log out and leave. Each render job can be prioritised, stopped, deleted etc using the monitor.
Unfortunately, the installation guide skips the really useful stuff about installing Manager and Server as a Windows service, so have a read from p63 of the 2011 installation guide here: http://download.autodesk.com/us/systemdocs/pdf/backburner2011_install_guide.pdf
Shame Inventor does not make use of backburner - nor Showcase or Navisworks or Revit - or any of the design suite products come to think of it. Wouldn't that be a simple thing to include as a cross-product benefit?
The setup you describe sounds great. I'd love to have access to that kind of render farm!
Two things I forgot to mention:
1. Make sure the same service pack is installed on every machine. With max 2014, renders from the RTM version are a noticably different shade to renders of the same scene by max SP1 - so when you put your animation together, some frames are lighter than others and it looks .... (insert your own expletive here).
2. 3ds max and backburner will need to be installed on all machines that you intend to use as rendering machines. You do NOT need to activate max because network rendering just uses a special runtime setting that does not launch the full max product.
Hello, the below message came from my colleague about Backburner and I also used it during my testing. Hope this can help you:
