Inventor Forum
BOM renumber iLogic code almost done, need help.
1 REPLY 1
DeerSpotter
949 Views, 1 Reply
i cant get the BOM to Renumber. See my code, for some reason it doesnt work. also if possible i would like for it to be renumbered by 001 not 1, and then sorted.
' Set a reference to the assembly document.
 ' This assumes an assembly document is active.
 Dim oDoc As AssemblyDocument
 oDoc = ThisApplication.ActiveDocument
 Dim oBOM As BOM
 oBOM = oDoc.ComponentDefinition.BOM
 Dim oBOMView As BOMView
 oBOMView = oBOM.BOMViews.Item("Parts Only")
 ' Sort the BOM
Call oBOMView.Sort("BOM Structure",True)
 ' Sort the BOM with a custom field
 Call oBOMView.Sort("TYPE",True)
 'Call oBOMView.Sort("Part Number",True)
 'This is the line that I want to use, but is inconsistent.
 Call oBOMView.Sort("BOM Structure",True ,"TYPE",True ,"Part Number",True)
 'Re-Number the BOM
 Call oBOMView.Renumber(1, 1)
Image and video hosting by TinyPic
See My LinkedIn Profile
1 REPLY 1
in reply to: DeerSpotter
You will probably have to set up a loop to increment through the bom rows.
I have attached a BOM cylce routine, a few edits may get you closer to what you want.
T.S.
