Inventor General
Active Contributor
Message 1 of 2 (144 Views)
BOM Settings for Drawings
144 Views, 1 Replies
10-02-2012 09:04 AM
The solutions that I have found to get an assembly bom on an assembly drawing are:
1. insert an assembly into an assembly.
2. make a virtual part or derived part.
3. make extra fields in the part and have the BOM column look at alternative iproperty fields.
In a part file that has a family table I want the configurations of some casted parts and some machined parts. the casted parts will have a drawing but no BOM, the machined parts will have a drawing and a BOM.
Then in an assembly file that has a family table I want configurations that use the configurations of the part file. Each of these assemblies will have a drawing that has a BOM that will call out the part that is is made from.
 i aplogize, 2012.
In other words I will have a casting that will be machined so I will need a casting drawing and a machine drawing that has a BOM telling what casting to use.
Is there any easy way to do this.
On top of that when I try to make a family table in an assembly I get a message "THE BILL OF MATERIALS CONTAINS VIEWS OR PROPERTIES NOT SUPPORTED BE CONFIGURATIONS. OONLY STRUCTURED FIRST LEVEL BOM VIEWS ARE SUPPORTED. THE BOM WILL BE CHANGED DURING CONVERSION".
I do not know what i changed so I do not know how to correct it.
Please help with any solutions.
THANKS!
blair
Message 2 of 2 (118 Views)
Re: BOM Settings for Drawings
10-02-2012 04:15 PM in reply to: BDUB2012
If you can get away with assembly features for your machining
Create your casting IPT
Place it into a IAM and use Assembly features for your machining to get your finished part.
You BOM will show the casting blank.
This is nice if you have a couple of different finished machined parts from the same casting, as all the assembly features stay within the IAM and don't propagate back to the IPT casting.
If you change the properties of each feature, you can make the appearance look machined were you have made the material feature cuts.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
