I have an assembly that uses reference parts. I do not want them in the BOM, but they are used in other drawings in the BOM. When I make them reference, the iso drawing view boundaries are not correct. Can I change the size? Crop will only decrease the size not increase?
Solved by SBix26. Go to Solution.
Edit View > Model State tab > Margin. Keep raising the number until you include everything you want to see. However, you do not have control of the increase in any particular direction; it's the same amount all around.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
It is greyed out. I have access to it when I create a new ISO view, but not edit one.
I had made all parts normal. The feature to change margins is only available if you have a reference part.
My previous work around was just to hide the entries in the BOM.
