Inventor General
tuliobarata
Message 1 of 1 (103 Views)
BOM+LOD - It loads the master assembly
103 Views, 0 Replies
03-01-2013 09:54 AM
Here with my projects I use the following method  to create the assemblies and then the IDW.
In the assembly i create 2 LODs with SUBISTITUTE, one with normal datails and one with almost nothing, just as a reference to others models and for a layout e.g..
In the top assemblies i user the first LOD SUB with normal details because it turns the IAM easy to work (if i use the MASTER LOD it becomes impossible to work with 100k ~ 200k parts in the IAM). So, when im working in the IAM everything is perfect, with JUST SOME parts loaded in the memory.
So when i need to go to IDW, I put the base view with my LOD SUB and i can work fine, untill I try to use baloon or even the BOM.... when I activate the BOM, ALL the assembly is loaded and then becomes impossible to work, like if in the LOD is loaded 20k parts....when I load BOM all the 200k parts are loaded, even with BOM PARTS ONLY DISABLED and with the right LOD selected  to use in the BOM.
So, is there a way to solve this ? Or isnt that a problem?
Because I think it makes no sense; If you create those Subistitutes its because you dont wanna load everything, but right in the end, everything goes to the memory.
Barata
IV 2013
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
