Inventor Forum
BOM Grouping
2 REPLIES 2
JoelMckone
912 Views, 2 Replies
BOM Grouping
I frequently need to list several parts with the same part number but with different discriptions and part formulas.  Inventor keeps grouping them even when I turn the group fuction off.  I just want inventor to list them by 'item' and I will sort them as required but I can't find a way to make this work.  Is it possible to do this?
Tags (2)
2 REPLIES 2
dave.anderson
in reply to: JoelMckone
Yes, you can disable the Bom Roll Up function. Here's a link to a skill builder on BOM in general: http://download.autodesk.com/us/inventorprofessional/pdf/skillbuilder_bom_structure.pdf
Pg15 explains what causes it to occur which is important to understand.
This WikiHelp link explains how to enable/disable Row Merge:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0611-Drawings611/0633-Drawing_63...
Dave Anderson
Sr. Support Engineer– CAM
Autodesk, Inc.
JoelMckone
in reply to: dave.anderson
Thanks - the links describe the problem I have been having.
