I frequently need to list several parts with the same part number but with different discriptions and part formulas. Inventor keeps grouping them even when I turn the group fuction off. I just want inventor to list them by 'item' and I will sort them as required but I can't find a way to make this work. Is it possible to do this?
Solved by dave.anderson. Go to Solution.
Yes, you can disable the Bom Roll Up function. Here's a link to a skill builder on BOM in general: http://download.autodesk.com/us/inventorprofessional/pdf/skillbuilder_bom_structure.pdf
Pg15 explains what causes it to occur which is important to understand.
This WikiHelp link explains how to enable/disable Row Merge:
