Inventor General
Valued Contributor JM.
Valued Contributor
JM.
Message 1 of 3 (226 Views)
Accepted Solution
BOM Grouping
226 Views, 2 Replies
09-18-2012 12:52 PM
I frequently need to list several parts with the same part number but with different discriptions and part formulas.  Inventor keeps grouping them even when I turn the group fuction off.  I just want inventor to list them by 'item' and I will sort them as required but I can't find a way to make this work.  Is it possible to do this?
Product Support
Message 2 of 3 (187 Views)
Re: BOM Grouping
09-26-2012 01:45 PM in reply to: JM.
Yes, you can disable the Bom Roll Up function. Here's a link to a skill builder on BOM in general: http://download.autodesk.com/us/inventorprofessional/pdf/skillbuilder_bom_structure.pdf
Pg15 explains what causes it to occur which is important to understand.
This WikiHelp link explains how to enable/disable Row Merge:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0611-Drawings611/0633-Drawing_63...
Dave Anderson
Premium Support Analyst – DLS Mechanical Design
Autodesk, Inc.
If I have answered your question, please "Accept Solution" so others may benefit as well.
Valued Contributor
JM.
Message 3 of 3 (180 Views)
Re: BOM Grouping
09-26-2012 02:25 PM in reply to: dave.anderson
Thanks - the links describe the problem I have been having.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
