Inventor General
Member
cwwalder
Message 1 of 2 (213 Views)
BIM Exchange
213 Views, 1 Replies
10-23-2012 12:56 PM
Hey everybody, not really sure if this is a inventor or revit question, but since everything seems to look right in inventor I figured I would ask here.
So anyways I am using 2013 inventor and revit. I am trying to use this BIM exchange in inventor and I am try to by creating a simple part/family with a couple of different sizes in a table. Everything looks good in inventor as far as the table having different size and when I activate one it changes the part. When I export I am going to tools, BIM exchange, hitting export and away she goes. There is only one export button and everything is pretty simple to understand. So inventor as far as I know, is good.
Now when I bring it into revit as the ASDK format from export with BIM exchange as I am getting is the model with whatever view happens to be active. I am not getting the table nor the parameters I set up for manually changing the family.
I have done some research and noticed that in previous verisons you needed to export the table in inventor after that model, but I am not seeing that option anywhere.
So my question is, am I missing something and you can no longer export parametric parts from inventor to revit, or is there another set I am missing either in the inventor setup or the import into revit?
I want to say thanks for any and all help.
Employee
shaoni
Message 2 of 2 (192 Views)
Re: BIM Exchange
10-23-2012 09:39 PM in reply to: cwwalder
ADSK file is a non-parametric model, so it cannot be driven through the table.
Table exporting you mentioned was a prototype we made to transfer iPart table from Inventor to Revit, you may know it from Labs.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
