despite searching this and other sites relating to the topic i have seen the mention and apparent posting of the code several times however for whatever reason it never seems to be available for view or download.
it is part of another utility though here: http://ipc.barok.dk/files/ReadMe.pdf and http://ipc.barok.dk/
more here: http://www.mcadforums.com/forums/viewforum.php?f=34&start=0
tutorials here: http://www.mcadforums.com/forums/viewforum.php?f=41
i have written the code for inventor 2010 to allow inspection of the scale of the first view that the user has generated, and the value is then saved into the custom properties of the inventor document under the Name of "Scale".
to finish the process, you make your title-block entry look at that specific custom property, i will post the code tomorrow for you to download and save into the API module that lives inside the inventor idw document. that way if you leave the code in the document and save the document as a template, it will always be available whenever you use that template in future.
if you need assistance just post the idw file and i will put it in for you and give it back. if the title block is something you do not wish to post on a publc forum just email it to me.
-mark.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
