Inventor Forum
Automatic StartMacro error help
1 REPLY 1
tomasmik
236 Views, 1 Reply
Hello, I am beginner in autodesk and VBA and got one little problem.
I already made my model in .ipt and want to change 3 parameters of my model via VBA macro. It works ok but only if I manually start macro in VBA editor/autodesk. But now i need to run this macro on startup when i open my .ipt file (document project).
I got an init error on my start up macro(cant change parameters(dimensions)of my model)
This is code in my Form:
Public Parameter As Inventor.Parameters
Private Sub UserForm_Initialize()
On Error GoTo ErrorHandler
Set Parameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
TextBox1.Value = 10 * Parameter.Item("dlzkadiery").Value
TextBox2.Value = 10 * Parameter.Item("diera1").Value
TextBox3.Value = 10 * Parameter.Item("vysunvystupku1").Value
Exit Sub
ErrorHandler:
MsgBox "Chyba pri inicializácii okna", vbCritical, "Chyba inicializacie"
End Sub
Private Sub ButtonUpdate_Click()
If TextBox1.Value <> "" And TextBox1.Value > 9 And TextBox1.Value < 101 Then
Parameter.Item("dlzkadiery").Expression = TextBox1.Value
Else: MsgBox "Dĺžka diery: Zadajte hodnotu v intervale 10-100mm", vbInformation, "Zmena hodnôt"
If TextBox2.Value <> "" And TextBox2.Value > 4 And TextBox2.Value < 61 Then
Parameter.Item("diera1").Expression = TextBox2.Value
Else: MsgBox "Priemer diery: Zadajte hodnotu v intervale 5-60mm", vbInformation, "Zmena hodnôt"
If TextBox3.Value <> "" And TextBox3.Value > 4 And TextBox3.Value < 101 Then
Parameter.Item("vysunvystupku1").Expression = TextBox3.Value
Else: MsgBox "Vysunutie vystupku: Zadajte hodnotu v intervale 5-100mm", vbInformation, "Zmena hodnôt"
ThisApplication.ActiveDocument.Update
Exit Sub
ErrorHandler:
MsgBox "Chyba pri zmene parametrov", vbCritical, "Chyba parametrov"
End Sub
Private Sub ButtonDefault_Click()
TextBox1.Value = 50
TextBox2.Value = 50
TextBox3.Value = 15
Exit Sub
ErrorHandler:
MsgBox "Chyba pri zápise defaultnych hodnôt", vbCritical, "Chyba hodnot"
End Sub
Private Sub ButtonExit_Click()
End
End Sub
 and this is code in my module
Public Sub EditParamsAutoOpen()
UserForm1.Show vbModeless
End Sub
 Fast help is greatly appreciated
1 REPLY 1
tomasmik
in reply to: tomasmik
bump, still need help, any tips ?
