Inventor General
New Member
Message 1 of 2 (136 Views)
Automatic StartMacro error help
136 Views, 1 Replies
11-01-2012 12:19 PM
Hello, I am beginner in autodesk and VBA and got one little problem.
I already made my model in .ipt and want to change 3 parameters of my model via VBA macro. It works ok but only if I manually start macro in VBA editor/autodesk. But now i need to run this macro on startup when i open my .ipt file (document project).
I got an init error on my start up macro(cant change parameters(dimensions)of my model)
This is code in my Form:
Public Parameter As Inventor.Parameters
Private Sub UserForm_Initialize()
On Error GoTo ErrorHandler
Set Parameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
TextBox1.Value = 10 * Parameter.Item("dlzkadiery").Value
TextBox2.Value = 10 * Parameter.Item("diera1").Value
TextBox3.Value = 10 * Parameter.Item("vysunvystupku1").Value
Exit Sub
ErrorHandler:
MsgBox "Chyba pri inicializácii okna", vbCritical, "Chyba inicializacie"
End Sub
Private Sub ButtonUpdate_Click()
If TextBox1.Value <> "" And TextBox1.Value > 9 And TextBox1.Value < 101 Then
Parameter.Item("dlzkadiery").Expression = TextBox1.Value
Else: MsgBox "Dĺžka diery: Zadajte hodnotu v intervale 10-100mm", vbInformation, "Zmena hodnôt"
End If
If TextBox2.Value <> "" And TextBox2.Value > 4 And TextBox2.Value < 61 Then
Parameter.Item("diera1").Expression = TextBox2.Value
Else: MsgBox "Priemer diery: Zadajte hodnotu v intervale 5-60mm", vbInformation, "Zmena hodnôt"
End If
If TextBox3.Value <> "" And TextBox3.Value > 4 And TextBox3.Value < 101 Then
Parameter.Item("vysunvystupku1").Expression = TextBox3.Value
Else: MsgBox "Vysunutie vystupku: Zadajte hodnotu v intervale 5-100mm", vbInformation, "Zmena hodnôt"
End If
ThisApplication.ActiveDocument.Update
Exit Sub
ErrorHandler:
MsgBox "Chyba pri zmene parametrov", vbCritical, "Chyba parametrov"
End Sub
Private Sub ButtonDefault_Click()
TextBox1.Value = 50
TextBox2.Value = 50
TextBox3.Value = 15
Exit Sub
ErrorHandler:
MsgBox "Chyba pri zápise defaultnych hodnôt", vbCritical, "Chyba hodnot"
End Sub
Private Sub ButtonExit_Click()
End
End Sub
 and this is code in my module
Public Sub EditParamsAutoOpen()
UserForm1.Show vbModeless
End Sub
 Fast help is greatly appreciated
New Member
Message 2 of 2 (111 Views)
Re: Automatic StartMacro error help
11-02-2012 03:36 AM in reply to: tomasmik
bump, still need help, any tips ?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
