Inventor General
New Member
banksae
Message 1 of 4 (1,280 Views)
Automatic Constraints still not working (Inventor 2011)
1280 Views, 3 Replies
06-15-2011 01:04 PM
Worked until recently.  I have tried all previously suggested solutions and read links to this problem but still can not get automatic constraints working again.  Constraint Inference and Persistence are on as is Persistent Dimension.  Any other suggestions?
*Expert Elite*
JDMather
Message 2 of 4 (1,274 Views)
Re: Automatic Constraints still not working (Inventor 2011)
06-15-2011 01:44 PM in reply to: banksae
What about Constraint Options?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
banksae
Message 3 of 4 (1,254 Views)
06-15-2011 08:55 PM in reply to: JDMather
They were all checked.  While waiting for reply, I checked another computer that was creating automatic constraints.  I copied all drawing, sketch, and part options.  Somehow that unchecked all my constraint options.  When I choose all constraint options again, automatic constraints were enabled.  I went back to toggle application options one at a time to see if I could recreate the problem - I could not.  I'm not sure what I did or undid originally and I wonder if there was a specific combination that caused the problem.  However, everything is back on track and I'm back to work.  Thank you for your help!
New Member
CRASHMYCOMPUTER
Message 4 of 4 (1,040 Views)
05-15-2012 04:07 PM in reply to: banksae
i was having the same problem and i found the solution
hover over the borowser and right click, go down to "constraing options" and make sure everything is selected.
good luck
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
