It's other constraints, perp and paral (possibly others) that cause the
problem, which you must not have had or you wouldn't have had to add the equ
constraints with two sides dimensioned. Try drawing a line between two
projected points, a line perp to one end of it and adding an equal len
constraint.
There is also an annoying change in driven dim behavior that I'd like to see
fixed: project two points, place work points on one or both. Try to dim. 6
dropped a driven dim, 7 gives an error message. (While they're at it I think
you should be able to dim without adding the work points and I do have apply
driven dim checked.)
"BTBeilke" wrote in message
news:7838F0EEAEFD702B6D3AAA28F0837EA6@in.WebX.maYIadrTaRb...
JJ,
I've seen other messages concerning this issue, but I have used the Equal
constraint quite often in IV7 and have yet to have any problems. As a
general rule, I tend to apply constraints before I add dimensions. I think
I remember another thread where someone suggested that they only had
problems if they tried to apply the Equal constraint after dimensioning the
sketch. However, I just tried drawing a box in a new sketch, dimensioning 2
sides of the box, then applying the Equal constraint to the opposing sides
of the box, and it worked just fine.
Blane
