It is not the first part of the error message
it is error 1308 Sourcefile not found program Program files\autodesk\inventor 2013\catalog\desktop.ini
I have tried EVRYTHING read the clean uninstall procedure, used the auto remove progrmam you make, used registry cleaners, removed every autodesk product.
I am at my wits end cant the write the words I want to say about this but I need a solution. Before I have to either do with out or reload windows.
Help
Solved by junkaphobia. Go to Solution.
Looks like registry entries, you have followed the installation requirements.
1.) Logged in with Administrative Privledges
2.) UAC slider set to lowest setting
3.) Some Anti-Virus software may require to be turned off and it's services stopped
4.) You are current on on O/S updates and hot-fixes
5.) .NET 4.5 is installed on the system
Possibly corrupt installation media...
Possible corrupt user profile.
create a new user on your computer (admininstrator) reboot log in as new user
It was a great suggestion but the exact same error message...what on earth now?
By the way I did follow all your instructions. As far as the install I also own 2012 and tried to install it and it gave the same message.
Hmm, lloks like it may have been the installer after all I tried it on my other computer and got the same message. I will consider this solved.
