Inventor General
ninjadead
Message 1 of 7 (1,257 Views)
Autodesk Inventor modeling guitar neck
1257 Views, 6 Replies
01-30-2012 02:24 AM
I have questions about using Inventor tools modeling.
I am currently using Autodesk Inventor 2008
What I want to model is an electric guitar neck which I am stuck in modeling the blend point near the neck joint (I uploaded the picture, highlighted with yellow rectangle), where the curve goes downward.
Along the length neck (from the string nut to the 15th fret (before the curve goes downward) I used the loft tool which works fine
If you are not clear or confused, or need more information please tell me.
Thank you,
Ninja
.Guitar neck blend point
JDMather
Message 2 of 7 (1,242 Views)
Re: Autodesk Inventor modeling guitar neck
01-30-2012 05:06 AM in reply to: ninjadead
Attach your ipt file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
ninjadead
Message 3 of 7 (1,206 Views)
01-30-2012 11:53 PM in reply to: ninjadead
Dear Community Mailer, here is the .ipt file
Thank you very much
ps. I attached another image which is an extrusion, exaggeration of the guitar neck what I'm trying to model.SG neck extrude.jpg
Active Member
bogdan.noreq
Message 4 of 7 (1,184 Views)
01-31-2012 08:01 AM in reply to: ninjadead
Hi!
I added a ipt. file and stp. file because I work at Inventor 2012 so maybe you are not be able to open it. But from snapshot you can see a tree. Think you was really close to finish your part. Ofcourse it is my opinion how to do thet - but I thinj it should work. Just make a loft using your scatches and made a cut by a vertical plate. You dont have to bent it- some times it is easy to find another way to do it! :smileyhappy:)  Good luck!
Autodesk Inventor Professional 2013
Windows 7 64-bit
JDMather
Message 5 of 7 (1,166 Views)
01-31-2012 09:05 AM in reply to: ninjadead
I noticed that your sketches are not constrained.
I recommend you start here http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
ninjadead
Message 6 of 7 (1,100 Views)
02-01-2012 08:57 AM in reply to: bogdan.noreq
Hi Bogdan,
My computer crashed, (not from inventor) just got it fixed and it's late night now. I saw your attached picture, from looking at the tree if I'm mot mistaken, you just lofted my part then delete face, trim, stitch? Looks simpler than I thought.
I'll continue with my part tomorrow. Thank you
Hi JD Mather,
Thanks for the Autodesk guideline, as I am new to Inventor.
I'll study and play with Inventor tomorrow.
Ninja
ninjadead
Message 7 of 7 (1,058 Views)
02-05-2012 06:38 AM in reply to: ninjadead
I'm back here to thank you, it is solved.
ps. prof. Mather, your stuff has many things that I didn't know and I am learning those.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
