Inventor General
Member
ni3_patkar
Message 1 of 6 (234 Views)
Autodesk Inventor become very slow while "save as" into another N/w machine
234 Views, 5 Replies
08-31-2012 05:44 AM
I am facing slowness issue while doing "Save As" step file in to another network machine. Same time, I am able to copy  step file directly in to network machine.
I would be greatful, if anyone gives me solution.
Thanks in advance.
Nitin
*Pro
jletcher
Message 2 of 6 (233 Views)
Re: Autodesk Inventor become very slow while "save as" into another N/
08-31-2012 05:47 AM in reply to: ni3_patkar
Hard to follow what you mean but we will need the version you are working with..
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Member
ni3_patkar
Message 3 of 6 (231 Views)
08-31-2012 05:57 AM in reply to: jletcher
I m using ver 2013. Actually, I am trying to copy n paste step file from one machine to another through Autodesk Inventor by using "Save As" option. But it takes 25-30 mnts to save.
Regards
Nitin
*Pro
jletcher
Message 4 of 6 (229 Views)
08-31-2012 06:02 AM in reply to: ni3_patkar
How large is it file size wise?
Have you done the same size file in 2012 and not have the same time issue?
What version of step are you exporting it?
Can you repeat this? ( just in case your network was busy)
Have you saved it to your local drive to test time issue ( in case network was busy)
James Letcher
Member
ni3_patkar
Message 5 of 6 (211 Views)
08-31-2012 10:36 PM in reply to: jletcher
Its hardly few KBs file.
We do not have 2012 version.
2013
Repeated atleast 5-6 times. Also did after restarting machine but didn't work.
It takes few seconds either to copy paste in local drive or save it from Autodesk Inventor 2013.
Also tried direct copy paste in another machine by mapping folder. It also takes hardly few seconds. It means there is no issue in network. We have only 3 computers in separate network and 1 CNC and 1 CNC Filling Machine. Same issue we are facing when we try to throw the data to CNC milling machine.
Member
ni3_patkar
Message 6 of 6 (199 Views)
09-01-2012 04:35 AM in reply to: ni3_patkar
214
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
