Hi ,
I have windows vista installed as OS - 64 bit
Can start professional 2012 and open the GUI , but not able to work further anymore.
Once GUI got open , if I attempt to do something on GUI , say for eg - just move mouse cursor ,
immediately the whole system hangs up.
It just leaves the option to shut down by pressing the shut down button and nothing else
I can very well operate other Autodesk products like - Moldflow / CAD Doctor etc...
Can request input , if anyone have experience the same behavior as above
Awaiting reply
Best Regards
vs
Solved by karthur1. Go to Solution.
Hi ,
I would like to add that , i could able to open a new part file (*.ipt) using standard(mm) template and then it hagns up everything
vs
Open the part file again. Now go to tools>Application options, Hardware Tab. Click on the "Diagnostics" button and then paste that information here.
Hi ,
Since I could not save the same ipt file , it won't be possible to open the same
I have open new .ipt file , please find attached dell.txt as requested , after click on "Diagnostic"
It still happens the same things , the whole system hangs up
!!!!!!!! Amazing thing is , Alias is working !!!!!!
Best Regards
vs
I was trying to get you to use software rendering just to rule out the video card. Start a new part, go to tools>Application options>Hardware tab, check "Software Graphics". Click OK to close dialog, close part (no need to save), close Inventor.
Start Inventor again. Start a new part. Go to Tools>App Options, Hardware Tab. Now click Diagnostics and paste that information here like you did before.
Can you work now? It may be slow, but at least it shouldnt hang like your original post.
As far as I can tell the ATI card is not supported.... that might be your problem.
Hi
yesterday I did the same , I checked the box for - "software graphics" , it works
But when I came out of the "Inventor" , again on the "Inventor" - The checked box for "Software Graphics" was unchecked
Now it remains checked , please find attacehd "software_graphics_checked.txt" as requested
I laso have increase the page file size , it shows me little improvement w/o check box for - "software graphics" , but finally it was making the whole system stand still / hang up. It works better with checked box for - software graphics
Thanking You
Best Regards
vs
I would say its your graphics card. Look here for a list of approved cards/drivers.
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
Hi ,
I have also search for other discussion post , please find below
http://forums.autodesk.com/t5/Autodesk-Inventor/IV-2012-Graphics-Settings/td-p/3008242
My graphics card is ATI Mobility Radeon HD 4570 with memory 512 MB, any idea which will be compatible from the suggested by Autodesk , I can see under AMD make , there are many
vs
update your graphics card driver to the latest version and then uncheck software graphics and go back to quality or whatever
