Inventor Forum
Autodesk Inventor Drawing
9 REPLIES 9
Message 1 of 10
Arya2012
1237 Views, 9 Replies
Hi all,
I have a question abut Inventor Drawing.
Ok, here is the question:  to reduce number of drawing and paper, I am trying to place multiple parts in one drawing. But there is problem, multiple parts has multiple unique part numbers and the drawing only assign one part number to the very first part which placed first in the drawing. The question is, is there a way that I can place more than one part with different unique part numbers in the drawing and the drawing title block assign different unique part numbers not only one?
Thanks.
Regards.
9 REPLIES 9
Message 2 of 10
Hi Arya2012,
Typically in mechanical design it is preferred to have one part = one drawing. However, in the world of fabrication design (structural steel, etc.) it's often common to detail multple parts on a single sheet.
If that is your situation, my suggestion would be to use a drawing number in the title block. This drawing number is often based on the job and sheet number. Then use a sketched symbol to report the part number of each part on the drawing.
This works well if you don't intend to place a parts list on the sheet. If you do need a parts list, then things become a bit more difficult.
Can you post an example PDF of a drawing that is configured the way you want it? I'm sure others will have other suggestions based on their direct experince once they see what you're after.
Here's a link that might provide some insight on the subject of coordinated parts lists:
http://cadsetterout.com/inventor/large-assemblies-coordinated-bom/
I hope this helps.
Curtis
Message 3 of 10
mcgyvr
in reply to: Curtis_Waguespack
Just set the title block information to be  "prompted". Then when you start a drawing a dialog box will come up and you can type in whatever you want to fill out the titleblock data.. It doesn't have to be pulled from the part properties.
Message 4 of 10
Arya2012
in reply to: Arya2012
Hi Curtis,
Here I attached a PDF file showing the issue.
You are right, I'm doing a lot of structural design which detailing multiple parts in a single sheet. So since I'm dealing with larger assemblies which consist of too many parts, I don't want to type all the info manually. I want the drawing to pull info from model.
Message 5 of 10
Hi Arya2012,
Here is my suggestion on how to set this up. Others might have suggestions to consider as well.
Basically you want your title block info to come from the drawing file's iProperties, and you'll set up a sketched symbol to call the model part number from the models' iProperties.
You could use a prompted entry as suggested by mcgyver, but then the information resides in the title block and not in the file, meaning that if you ever need to switch out the title block using the Drawing Resources Transfer Wizard, you would loose the prompted entry information.
Hopefully you can follow these images (I've attached them also, so you can see them at full size).
I hope this helps.
Curtis
Message 6 of 10
drlamb
Just a thought but you could also add it to your view label.
Donald L.
Inventor Product Design Suite 2016
Windows 7 Professional - 64 bit
HP h8-1380t - i7-3820 @ 3.6 GHz
16 Gb
AMD Radeon HD7950 3Gb
Message 7 of 10
Arya2012
in reply to: drlamb
How ????
Message 8 of 10
drlamb
Donald L.
16 Gb
Message 9 of 10
Thanks Curtis, works awesome.....:)
Message 10 of 10
Curtis_Waguespack
in reply to: drlamb
Hi drlamb,
Adding the part number property to the view label is a good suggestion, and is of course more automatic than using a sketched symbol. Just, keep in mind that it will add this to the view label of all views that use that particular standard, so it might take some thought to set up templates to pull the PN into the view only when needed. Of course, we could just edit the view label and remove the PN once placed too.
Curtis
