Inventor Forum
Autodesk Inventor Drawing Font Size Issues
3 REPLIES 3
daltonputman
2975 Views, 3 Replies
In the Autodesk Inventor drawing (.idw) I am unable to change the font size when i dimension a hole and thread. I have tried going into "Edit Hole Note" and "Text" when you right click on the dimension. Any help would be appreciated. The file I am trying to change is linked below.
3 REPLIES 3
cbenner
in reply to: daltonputman
Welcome to the forums.
Dimension text size, and any other of these types of settings are set and changed using the Styles Manager, found on the Manage tab.  You can create and edit multiple styles for different purposes, and then set the currently enabled one using the Object Defaults setting.
This is a link to the help section on the style manager... to get setting s to be used in all of your drawings, set them in your templates.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?contextId=REDIRECT_IDD_OBJECT_DEFAULTS_PAGE
daltonputman
in reply to: cbenner
I am unable to change anything in the Object Defaults due to the fact that this is on a computer that does not have the rights to do it. I have been working to solve this problem but no luck so far. Thank you for your help in advance.
daltonputman
I figured out that i needed to make copies of the note text so that i could edit it without messing every other dimension up. Thank you for pointing me in the right direction and ultimately solving the issue.
