We recently installed PDSU 2015 and we have noticed some issues with the Graphics in Inventor. We have downloaded the latest drivers from Nvidia and we have K5000 cards with 24GB ram. The outer boundries appear to be wireframe. Is anyone else having the same issue and know of a solution?
Solved by bob_holland. Go to Solution.
24GB on the graphics card..... WOW!!! What does a card like that set you back? My GeForce card has one (1) GB and cost about $150 3 yrs ago.
No problems like that here. Can you post a screen shot? What setting are you using under Tools >Hardware tab?
They will probably want you to post a Hardware diagnostics. This is found under Tools > Hardware >Diagnostics..... them past this to a txt file and post the txt file here.
I'm sorry we have 24GB of ram on the computer the video card has 4GB. We have tried messing with all the different settings and drivers, with no avail. I am curious to see if this might have to be an issue fixed with a service pack.
i am using the Quadro K 5000m with Inventor 2015
i am not seeing this
can you post a screen shot of what you are seeing?
DarrenP
What setting are you using on the hardware tab? I always use the "performance" setting and on the Display tab, I use "Smoother". This gives me a good mix between performance and speed, Especially when working with large models.
Post a screen shot (if you can) and the hardware diagnostics file.
Kirk
i am using Quality and Smoother for mine
DarrenP
Fori123,
I have NOT seen a case like that come through support.
Please provide a screenshot of what you are seeing.
Can you also have someone login to this computer that has never run Inventor and see if the issue is still there for the other user.
Thank you.
