Dear support team/Autodesk user,
I have neen trying to install Autodesk inventor 2014 on my new windows 8 PC with no success after many trials, however making sure after each trial to delete temporary files, setting the security for users to full access and turn off my anti-virus everytime. I want to use autodesk in order to use it for my personal education project regarding mechanical engineering field, which include stress analysis, 3D design and CFD analysis since I only got to do so on Pro Engineer and want to try autocad. I have attached all the necessary files of what I have been getting from snap shots and installation log files as a zip folder. Please note that I have barely downloaded any other programs apart from the necessary ones( Adobe reader latest edition, and microsoft office). Can anyone please advice about the matter.
Thanks.
I would try using the option to only Save the file to a location and then after it's fully downloaded and saved then run the Installation.
I would also look to get access to a faster network. The "1 day 6 hour remaining" is probably part of your problem and the intergrity of the download package.
Blair,
Thank you for your reply, I have done as you suggested with using the donwload option which saves it and downloads to postpone installation at a later time. However, the installation took less time but gave the same results as before. I cannot understand what the installation logs are telling me or whats causing the error (1603 or 1619).
Hi ymachou,
I posted some links on your other post:
I hope this helps.
Curtis
