Inventor Forum
Autodesk Download Manager aborted error 0x28000002
4 REPLIES 4
andymeek1621
4018 Views, 4 Replies
Trying to download Inventor 2015 and keep getting following error message (attached).
Tried restart of computer and download again, same error
4 REPLIES 4
rkmcswain
in reply to: andymeek1621
You might also try posting this in the Installation and Licensing forum.
R.K. McSwain     | CADpanacea | on twitter
Paul-Mason
I also had this problem with the 64 bit down-loader but not with the 32bit for some strange reason, don't know why BUT it seem that Autodesk have still done bugger all to fix this problem.
Then the board admin moved the post - I'm still waiting for any replies as to a fix.
The installer.exe is duel 64 and 32 bit ther should be two folders one x64 and the other x86 so IF you can try to down load on a 32bit machine copy the file to at least a 25GB external device and transfer to you 64 bit machine and install as normal.
It's a bit of clart around but it works.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
mcgyvr
in reply to: Paul-Mason
I had the same problem.. I just did the other option to download without that Download Manager software.. Just browser download I believe.
engtalha13
in reply to: mcgyvr
How did you download using without the Autodesk download manager? Please share the steps as I am having trouble downloading Moldflow. Thanks !
