Inventor Forum
AutoCAD Solids Won't Import
1 REPLY 1
343 Views, 1 Reply
When I import an AutoCAD DWG that contains multiple solids into Inventor 2012, only half of the solids import. To get all of the solids into Inventor I had to first open the DWG solids in Fusion (all the parts opened correctly), then saved the DWG as a Fusion DWG and then I was able to import all of the solids into Inventor. A sample DWG file is attached. Any thoughts?
Dan
1 REPLY 1
jeffrey.sun
Hello Danbanach,
    This is a known issue. We are trying to fix it.
    The good news is you have already found a workaround to avoid this issue.
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
Autodesk, Inc.
