I am currently using AutoCAD Inventor Suite 2011.
My problem is that my screen keeps freezing.
Everything BUT the screen seems to be working.
My ribbon functions fine, I can select diffrent parts on my browser (though it wont show on "frozen screen"), see the cursor location points (X, Y) changing, ect..
However when I minimize tab and open tab again its fine.....UNTIL MY NEXT COMMAND.
This is making it impossible for me to work. Having to change tab for every move/command.
Things i have tried to far:
1. Hotfix
2. Updates
3.Changing "Application Options>Hardware" settings
4.Changing "Application Options>General" paging setting
5.Changing "Application Options>Display" FPS setting
6. Uninstall/Installing
Nothing is fixing this problem
Please help
Running:
Windows 7 (32 bit)
Intel(R) Core(TM) i5-2410M CUP @ 2.30Ghz 2.30GHz
4.00 GB (RAM)
Intel(R) HD Graphics Family
Solved by Cadmanto. Go to Solution.
Welcome to the forum.
Sounds like it might be a graphics issue. When was the last time you upgraded your graphics driver?
Did this just start happening? Or did something happen like an upgrade of some kind whether it is a new anti-virus software or what ever.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You are most welcome.
I am glad I could help you resolve your issue.
