Inventor Forum
Auto cut lines to cropped view
5 REPLIES 5
959 Views, 5 Replies
I have several cropped views in an Inventor 2013 drawing. I was wondering if Inventor could auto add a cut line to the cropped edge of objects when creating these views or alternatively if I would have to manually add a cut line through the symbols library ?
5 REPLIES 5
mpatchus
You could try adding a Layer to the styles named "Crop Cut Line" and define the line style for that layer.
Then assign that layer to the Object Defaults for the Crop Cut Lines.
Haven't tried it personally, but it may get you what you need.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
Hi. Thanks for you response. Please could you describe how to implement this method you have described to obtain the cut lines as I am not sure as to how to add these cut lines you have described. Many thanks.
mpatchus
Inventor 2025 Beta
Thanks, I will give this a go. Smiley Happy
mpatchus
You can tweak the line type and line weight as needed to achieve the desired result.
Inventor 2025 Beta
