Inventor General
Distinguished Contributor
Anthony
Message 1 of 6 (371 Views)
Auto cut lines to cropped view
371 Views, 5 Replies
08-23-2012 03:53 AM
I have several cropped views in an Inventor 2013 drawing. I was wondering if Inventor could auto add a cut line to the cropped edge of objects when creating these views or alternatively if I would have to manually add a cut line through the symbols library ?
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Valued Mentor
mpatchus
Message 2 of 6 (369 Views)
Re: Auto cut lines to cropped view
08-23-2012 04:10 AM in reply to: Anthony
You could try adding a Layer to the styles named "Crop Cut Line" and define the line style for that layer.
Then assign that layer to the Object Defaults for the Crop Cut Lines.
Haven't tried it personally, but it may get you what you need.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Anthony
Message 3 of 6 (359 Views)
08-23-2012 05:53 AM in reply to: mpatchus
Hi. Thanks for you response. Please could you describe how to implement this method you have described to obtain the cut lines as I am not sure as to how to add these cut lines you have described. Many thanks.
Valued Mentor
mpatchus
Message 4 of 6 (357 Views)
08-23-2012 06:08 AM in reply to: Anthony
Mike Patchus
Anthony
Message 5 of 6 (355 Views)
08-23-2012 06:11 AM in reply to: mpatchus
Thanks, I will give this a go. :smileyhappy:
Valued Mentor
mpatchus
Message 6 of 6 (353 Views)
08-23-2012 06:29 AM in reply to: Anthony
You can tweak the line type and line weight as needed to achieve the desired result.
Mike Patchus
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
