Inventor General
Valued Contributor
Billduck
Message 1 of 3 (307 Views)
Auto constraints
307 Views, 2 Replies
05-04-2012 06:27 PM
Helping a friend. When I draw a line at the origin, it does not find the origin and snap to it, or auto apply the horizontal constraint when near horizontal. Or if I draw an L the lines are not connected. That is, I can pull one line away from the other. I can not find the settingsto correct this behavior. What's up?
Product Support
Daren.Lawrence
Message 2 of 3 (273 Views)
Re: Auto constraints
05-10-2012 01:33 PM in reply to: Billduck
My gut is telling me your constraint options for sketching are all disabled, but I’d also like you to check the sketch tab on the application options as well to make sure you’re auto-projecting the center point on sketch creation.
To get to the constraint options in your sketch, RMB in the graphics window while in a sketch and pick “constraint options” from the overflow menu. Please see the attached images.
Please mark as solved if this answers your questions or let us know if it doesn’t resolve it. Thank you.
Daren Lawrence
Product Support Specialist
MFG Support - Inventor
http://beinginventive.typepad.com/being-inventive/
JDMather
Message 3 of 3 (251 Views)
05-10-2012 03:18 PM in reply to: Billduck
Is this 2010?
Check Constraint Persistance as well (looks like Perpendicular Constriant - but isn't).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
