Inventor Forum
Auto Attach Detail Windows
4 REPLIES 4
rcmike
329 Views, 4 Replies
Is there a way to Auto Attach a window when you create the detail view. I don't want to keep creating the view then have to turn around and attach it. That seams like way more steps than it should be.
4 REPLIES 4
dave.anderson
in reply to: rcmike
Are you referring to the option to change the Cutout Shape from Jagged to Smooth and use the Display Full Boundary Detail? This is the only thing I could think of that meets what I think you're attempting to do.
I believe you are asking if there's an option to set this as the default behavior. Please let me know if I misunderstood.
Dave Anderson
Sr. Support Engineer– CAM
Autodesk, Inc.
rcmike
in reply to: dave.anderson
No I am not. I am talking about when you create a detail view it is either a circle or a rectangle. Then if I make a change to the size of the drawing the view does not stay in place unless I attach it. Is there a way to auto attach the views so when I change the model in size the view moves with the changes.
dave.anderson
in reply to: rcmike
Ah, I see now. You're spot on. Here's a link to the Product Feedback site where you can make this enhancement request:
I think having the option for a check box to Attach in the Detail View dialog box would be a great addition!!
Dave Anderson
Autodesk, Inc.
salariua
in reply to: rcmike
We shouldn't ask for it, it should have been available in the first place.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
