I can't post the assembly because of proprietary issues- my apologies. Hopefully I can describe the process well enough to make sense of the issue and the attached picture will maybe help.
I am trying to create a fixture, and there are many components that need to be bolted on. Rather than measuring each and every hole on many different pieces, I tried editing the components that parts will bolt to and did this:
In another test, not moving the part but simply changing the geometry the second part feature updated properly.
Hi
Why not use the Bolted Connetion tool to create holes and insert the fasten components at the same time? Very easy!
When I moved the component being bolted in to with the circular reference the bolt holes did not move with the component. The bolts moved with the component, but the holes did not.
Also, even when I hit apply, I had to chose the start and termination planes and the hole type and fastener type all over again, which is much more time intensive- is there a way to keep that information and just choose another circular reference? That may be faster than what I originally did, but it would still only work if it can be made associative to the reference.
This particular assembly has almost 30 components bolted on with 2-4 holes in each, so if they start to need to be adjusted it becomes a hassle pretty quickly.
