Inventor General
Distinguished Contributor
SteveFrey
Message 1 of 11 (386 Views)
Associating Two Sketches In A Frame Generator Assembly
386 Views, 10 Replies
09-04-2011 08:49 PM
I have sketches that are used in framed shower door assemblies and I am trying to use the main sketch as the outside perimeter w/ associated parts while the door is separate so it can pivot independently from the rest of the assembly.  My question is:  How do I associate the door sketch to change size when the door opening changes size in the main sketch?
Steve Frey
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Employee
adsloud
Message 2 of 11 (369 Views)
Re: Associating Two Sketches In A Frame Generator Assembly
09-05-2011 06:35 AM in reply to: SteveFrey
Hi Steve,
For now, Inventor doesn't have such functionality to associate geometries between two sketches. We've already taken this into consideration and try to make this in the future. Thank you very much for pointing out your questions.
Best Regards,
Debbie
Debbie Lou
SQA Engineer
Design, Lifecycle & Simulation Group
SteveFrey
Message 3 of 11 (356 Views)
09-05-2011 09:02 AM in reply to: adsloud
Thanks Debbie.  What about using a dummy parameter file to drive the sizes?
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
Distinguished Mentor
rdyson
Message 4 of 11 (351 Views)
09-05-2011 09:58 AM in reply to: SteveFrey
Attached is a quick example of what I understand you are asking for
May well be wrong in my understanding, though
Adjusting either of the two parameters in the FrameSketch will propagate to the door part
SteveFrey
Message 5 of 11 (342 Views)
09-05-2011 06:17 PM in reply to: rdyson
Looks like you understand what I'm trying to do.  So from what you created I would open the Door&FrameTemp.iam and control it from the FrameSketch.ipt.  Now I just need to understand how you linked the two successfully.  It's been a while since I tried it.  I'll give it a try and let you know how I make out.  Thanks!
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
SteveFrey
Message 6 of 11 (336 Views)
09-05-2011 06:54 PM in reply to: rdyson
Okay, now that I'm thinking about this the model you sent to me is simple enough to do without associating the frames.  Where it starts to be more complicated is when there's a door with at least one fixed panel like in the attached image.  Now the door size (26") will drive the panel size (11.027") or if I change the overall width (40") the door stays the same but the fixed panel changes accordingly.  I've done this in the SK (attached) but like I said I need the door to swing open in the assembly as a representation.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
rdyson
Message 7 of 11 (287 Views)
09-06-2011 09:07 AM in reply to: SteveFrey
Not sure I understand the problem here.
SteveFrey
Message 8 of 11 (284 Views)
09-06-2011 09:49 AM in reply to: rdyson
That looks like it works.  I guess I'm not understanding how to link the two frames together.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
rdyson
Message 9 of 11 (276 Views)
09-06-2011 10:49 AM in reply to: SteveFrey
SteveFrey
Message 10 of 11 (218 Views)
09-14-2011 08:30 PM in reply to: rdyson
I tried to do this many times but I'm not able to link the parameters.  Can you give me any pointers?  Thanks.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
