I'm a contractor, I've created a really impressive form-driven assembly containing various iLogic rules. However, as i add more rules it is beginning to slow down (increase rule processing time). Should I suggest upgrading to 64-bit and increasing RAM or will that not help?........could be costly with no increase in performance.
Processor: i7-2600
OS: 32-bit
RAM: 4.00GB
Inventor 2012
Lewis
I find when using Inventor for assemblies, I am often using more than 4GB (I have 12Gb available). Try CTRL+ALT+DEL -> Task Manager -> Performance, to see if you are pushing your available memory to it's limits.
If you are, increasing the RAM should improve your perfromace a lot.
Alternatively, could you reduce useage by getting rules only to trigger when needed?
Wayne
