Inventor General
Active Contributor
Message 1 of 5 (70 Views)
Assembly variants
70 Views, 4 Replies
11-05-2002 04:08 PM
I have an assembly file and associated drawing file. How do I create a modification (or new variant) and keep the original files. "Save copy as" works fine for the assembly but when I us it for the drawing I cannot find a way of pointing the new drawing at the new assembly.
Valued Contributor
Message 2 of 5 (70 Views)
Re: Assembly variants
11-05-2002 04:48 PM in reply to: bobpeak
Save copy as on both the assambly and the drawing.
Temporary rename the old assambly.
Open the new drawing, when it cant find the old assambly, point to the new assambly.
Save.
Rename the old assambly to its original name.
Active Contributor
Message 3 of 5 (70 Views)
Re:
11-05-2002 07:52 PM in reply to: bobpeak
another way:
open the idw with the Design assistant
copy all files you need (iam , ipt and the idw) to new names.
plan carefully what parts and assy need to have new names, otherwis you mess up the old assy.
Stefan
Active Contributor
Message 4 of 5 (70 Views)
Re:
another way:
Stefan
*Maas, Karl
Message 5 of 5 (70 Views)
Re:
11-05-2002 10:50 PM in reply to: bobpeak
another way: this would be best if you wanted to
try a few what-if scenarios.
- copy the parts that are going to change to
a new directory
- create a new project with this new directory as
the "personal workspace for group project"
- define the "group project file" as the IPJ of
your existing project
- make this new project the current
project
- modify your copied files, and open your
assembly
the assembly should find the modified files first
and not look any further. then it will find the rest of the files that didn't
change because the first instance of them will be in the workgroup
directory.
If you're changing parts in the assembly, you
should consider the other methods mentioned or look into design views where you
could control the visibility of parts.
K
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Save
assambly.
Save.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
