I'm working on a small Assy (25 parts). When I open one of the parts from this Assy and work on it then go back to the Assy many parts are not visible. The update button is usually off so I can't use it.
This started only about 2-3 weeks ago - in every assy. I changed the nvidia driver but didn't help.
Any idea how to fix this?
Inventor pro 2012
Win 7 Pro. sp1 64 bit
Intel Core I7-2600 CPU
Ram - 8GB
Quadro 2000 D
Nvidia 275.89 (tested nvidia 296.70 with no luck)
@alon wrote:Assy many parts are not visible.
Attach assembly with two parts - one that is still visible and one that is not visible exhibiting the behavior you describe.
Thank you.
I'm attaching 2 pdf files that show the problem. This is what I get on any assy I work on.
The no. 1 file is the assy before I started working on parts and no. 2 is what I get when I go back to the Assy.
I tried using "Rebuild All " as Scott wrote and it works - all the parts are visible again. I still would like to know what happened that caused this problem in the last 3 weeks
Alon
