Inventor Forum
Assembly part not moving
14 REPLIES 14
Message 1 of 15
tmccar
4728 Views, 14 Replies
I have been working on an assembly and have added a constraint which aligns the work axis of one circular part with another. Previously , I had been able to 'click and drag' one component along the axis of the other, but now it will not move. What could be the reason for this?
Tom
14 REPLIES 14
Message 2 of 15
in reply to: tmccar
Tom,
Could you zip and post a simplified one so I can help take a look?
Jacob
Message 3 of 15
tmccar
in reply to: tmccar
Hi Jacob
See attached zip file. I want to be able to move the nozzle away from the body, by clicking & dragging.
Regards
Tom
Message 4 of 15
in reply to: tmccar
il giorno 17/12/2007 14.00 tmccar ha scritto:
> Hi Jacob See attached zip file. I want to be able to move the
You have to add the parts also, not only the assembly file.
M.
Message 5 of 15
in reply to: tmccar
You have to put the parts in the zip file too
Message 6 of 15
in reply to: tmccar
Ok, I found that they are inventor samples, I only had to reference
the parts again.
I have no problem in sliding the nozzle up and down.
M.
Message 7 of 15
tmccar
in reply to: tmccar
Here is the zip file with the 2 parts
Message 8 of 15
mcgyvr
in reply to: tmccar
If your trying to move the body..it won't move because its grounded. (right mouse click on it and uncheck "grounded")
The nozzle slides freely along the axis in the files you posted.
Message 9 of 15
in reply to: tmccar
Seems ok to me. Have you tried to delete the constraints and select them again?
Message 10 of 15
JDMather
in reply to: tmccar
Make sure you haven't changed the selection priority to Feature or Face.
Restart Inventor and see if the problem persists.
Reboot the computor and see if the problem persists.
Message 11 of 15
tmccar
in reply to: tmccar
Hi JD
How do I check that?
Tom
Message 12 of 15
JDMather
in reply to: tmccar
Selection Filters
I believe if you followed the other suggestions the filters would have been reset.
Message 13 of 15
tmccar
in reply to: tmccar
You're absolutely right JD. It works after a restart, so the priority must have got changed somehow.
Tom
Message 14 of 15
in reply to: JDMather
I'm having the same issue, and restart / reboot does not fix it. This started happening to me suddenly out of the blue. We have INV 2014. Please help, thanks.
Message 15 of 15
JDMather
Did you read the second response.
Follow that instruction and end all doubt.
