Inventor General
Member
Message 1 of 6 (359 Views)
Assembly drawing view issue
359 Views, 5 Replies
11-01-2012 02:39 AM
Hi all,
I am having an issue with an assembly view (Picture attached).  When I do my base view, inventor is showing one part in the assembly as hidden lines and it cuts the end off it (the stairs).  Even with hidden lines removed it shows all lines for the stairs as hidden.  I can sort that out by amending the line style and hidden line calculation in the model state settings but the view still cuts the end off the stairs.  I have done a drawing of the stairs alone and the view is as you would expect, not all in hidden lines and the full view is there.
Has anyone come across this before or have any pointers on how I might sort this?
Thanks in advance
PaulMunford
Message 2 of 6 (335 Views)
Re: Assembly drawing view issue
11-01-2012 05:56 AM in reply to: vaughangilliam
Do you have the BOM property of the stairs set as reference?
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Member
Message 3 of 6 (315 Views)
11-01-2012 08:55 AM in reply to: PaulMunford
Hi there,
The BOM structure is currently set to 'Default (Reference)'.  In iProperties the only options in the Occurence tab are 'Default (Reference)' or 'Reference'.  Is there any way to add a new BOM structure?
The file for the stairs was downloaded from Grabcad as an inventor ipt.
Many thanks
karthur1
Message 4 of 6 (300 Views)
11-01-2012 09:56 AM in reply to: vaughangilliam
Open the assembly. Right click on the stairs in the model browser, choose "BOM Structure" and pick "Normal".
When you do that the stairs will now show in the parts list and be included in the mass calculations for the iam.
One way to access all the BOM structures is to open the part.  Then go to Tools>Document Settings, Bill of Materials tab.  Change the Default BOM structure there.
Member
Message 5 of 6 (264 Views)
11-02-2012 01:56 AM in reply to: karthur1
Good morning.
Please see picture attached.  There is no option other than reference.  It is either 'Default (Reference' or 'Reference'.  In the iProperties under occurence it is the same.  Is there a way of adding a new BOM structure?
Many thanks
Member
Message 6 of 6 (263 Views)
11-02-2012 01:58 AM in reply to: vaughangilliam
Sorry, I missed the last part of your message.  Doing it via document settings has worked thank you.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
