Inventor Forum
Assembly cut out
6 REPLIES 6
225 Views, 6 Replies
Assembly cut out
In an assembly, is it possible to make a cut out on a part such that I can see
the parts behind through the cut? If so, how is this done?
Erich
6 REPLIES 6
I should have said that I am talking about an idw assembly
Erich
Look into break-out sections
"Erich Koch" wrote in message
news:3DEE8BB7.8FFA4885@aerovironment.com...
> Erich
Hi Erich
Sounds like you are looking for Breakout views. You should be able to find them in Help
Kent
Member of the Autodesk Discussion Forum Moderator Program
> Erich
As the others stated broken sections are the way to go. I just figured them out yesterday. Some bumps in the road I had were getting the sketch associated with the view that the broken out section is in and depth.
depth is the easy one depth is NOT a negative distance. Yes I put a - value in and got nothing. Yes it makes all the sense in the world but sometimes that happens.
sketching in the view wasn't too difficult either.
I found highlighting in the browser was easier than picking the views.(some of mine overlap each other.) then hit the sketch button. the sketch grid did not always look OK whe I did that and I don't know why. once it was smaller than the view and looked incomplete and twice it was larger than the view. I am not sure why but it worked all 3 times.
When it did not work was when my sketch was not under the view in question. I just deleted it and redefined the sketch properly.
Thanks to you all.
Erich
> happens.
You can pick on geometry to set the depth as well.
~Larry
news:3DEF6780.ACD96688@aerovironment.com...
> Thanks to you all.
> Erich
them
associated
value in
that
> > happens.
views.(some of
did not
than
am not
question. I
