Inventor General
*Koch, Erich
Message 1 of 7 (83 Views)
Assembly cut out
83 Views, 6 Replies
12-04-2002 07:10 AM
In an assembly, is it possible to make a cut out on a part such that I can see
the parts behind through the cut? If so, how is this done?
Erich
*Koch, Erich
Message 2 of 7 (83 Views)
Re: Assembly cut out
12-04-2002 07:11 AM in reply to: *Koch, Erich
I should have said that I am talking about an idw assembly
Erich
*Corbin, Brian
Message 3 of 7 (83 Views)
Re:
12-04-2002 07:24 AM in reply to: *Koch, Erich
Look into break-out sections
"Erich Koch" wrote in message
news:3DEE8BB7.8FFA4885@aerovironment.com...
> Erich
*Keller, Kent
Message 4 of 7 (83 Views)
Re:
12-04-2002 07:29 AM in reply to: *Koch, Erich
Hi Erich
Sounds like you are looking for Breakout views. You should be able to find them in Help
Kent
Member of the Autodesk Discussion Forum Moderator Program
> Erich
Distinguished Contributor
Message 5 of 7 (83 Views)
Re:
12-04-2002 08:59 PM in reply to: *Koch, Erich
As the others stated broken sections are the way to go. I just figured them out yesterday. Some bumps in the road I had were getting the sketch associated with the view that the broken out section is in and depth.
depth is the easy one depth is NOT a negative distance. Yes I put a - value in and got nothing. Yes it makes all the sense in the world but sometimes that happens.
sketching in the view wasn't too difficult either.
I found highlighting in the browser was easier than picking the views.(some of mine overlap each other.) then hit the sketch button. the sketch grid did not always look OK whe I did that and I don't know why. once it was smaller than the view and looked incomplete and twice it was larger than the view. I am not sure why but it worked all 3 times.
When it did not work was when my sketch was not under the view in question. I just deleted it and redefined the sketch properly.
*Koch, Erich
Message 6 of 7 (83 Views)
Re:
12-04-2002 10:49 PM in reply to: *Koch, Erich
Thanks to you all.
Erich
> happens.
*Caldwell, Larry
Message 7 of 7 (83 Views)
Re:
12-05-2002 02:48 AM in reply to: *Koch, Erich
You can pick on geometry to set the depth as well.
~Larry
news:3DEF6780.ACD96688@aerovironment.com...
> Thanks to you all.
> Erich
them
associated
value in
that
> > happens.
views.(some of
did not
than
am not
question. I
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
