Inventor Forum
Assembly cut color change
2 REPLIES 2
cadcamm99
376 Views, 2 Replies
I am using Inventor 2014.  I have an assembly where one parts has to be trimmed after assembly.  When I do the cut in assembly, the part turns to a different color (black).  Any ideas?  My current view rep in assembly is Default.
2 REPLIES 2
mcgyvr
in reply to: cadcamm99
more than likely the "chunk" of material that you are cutting away had its color modified from default for that body..
Cadmanto
Can you post a screen shot?
Are your graphics drivers up to date?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
