I am using Inventor 2014. I have an assembly where one parts has to be trimmed after assembly. When I do the cut in assembly, the part turns to a different color (black). Any ideas? My current view rep in assembly is Default.
more than likely the "chunk" of material that you are cutting away had its color modified from default for that body..
Can you post a screen shot?
Are your graphics drivers up to date?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
