Inventor General
New Member
jeedee78
Message 1 of 6 (751 Views)
Assembly components in an oval pattern
751 Views, 5 Replies
04-09-2013 09:10 PM
In Inventor 2012 I know that it is possible to arrange assembly components in a circular or rectangular pattern. But is there a way to arrange these components in an oval pattern?
PaulMunford
Message 2 of 6 (726 Views)
Re: Assembly components in an oval pattern
04-10-2013 12:21 AM in reply to: jeedee78
Have you tried patterning along a path?
http://www.cadprofessor.in/2010/09/pattern-along-a-path-using-inventor-2011/
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Active Contributor
Jaychale
Message 3 of 6 (685 Views)
05-09-2013 01:35 PM in reply to: PaulMunford
That only applies to features in a part.
The pattern menu in an assembly looks different, and does not respond to a path, only a direction.
jtylerbc
Message 4 of 6 (675 Views)
05-09-2013 02:49 PM in reply to: Jaychale
Can you create a curve-driven pattern of something (work points, maybe) in one of your parts, then use "Feature Pattern Select" in your assembly pattern to follow the points?
John Tyler
Inventor 2013
Windows 7 64 Bit
Active Contributor
Jaychale
Message 5 of 6 (673 Views)
05-09-2013 02:54 PM in reply to: jtylerbc
I have been trying to do just that for the last hour or so.
Sometimes I can get the points to go where they are supposed to, but then it always tells me that something undetermineable is wrong.
JDMather
Message 6 of 6 (641 Views)
05-10-2013 06:45 PM in reply to: Jaychale
Alttach the files here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
