Inventor General
mrattray
Message 11 of 15 (143 Views)
Re: Assembly Rectangular Pattern
09-10-2012 09:29 AM in reply to: csaba.stupak
csaba.stupak wrote:
Of course if you know in advance that the hole will be used in the assembly ...
Just wondering, what scenario would that be where your putting a hole into a part that you don't know wether it will be used in the assembly?
Mike (not Matt) Rattray
Employee
csaba.stupak
Message 12 of 15 (141 Views)
09-10-2012 09:34 AM in reply to: mrattray
You are right in most cases the hole is used by a screw. :-)
Let me suggest another idea. If you know in advance that the patterned hole will be used by a screw, I suggest to attach/mark the 1st hole with iMate (Insert type). In most cases the screw has iMate at the "correct" location or you can edit the screw part and add a similar iMate (Insert type) to the screw. In the assembly you can create a constraint/iMate result which will put together the hole with the screw. In this case we have more steps and this workflow is good when you have more pieces of the part with patterned hole.
Csaba
mrattray
Message 13 of 15 (138 Views)
09-10-2012 09:36 AM in reply to: csaba.stupak
That would definately work well for a part that is reused frequently!
pbrooke
Message 14 of 15 (115 Views)
09-11-2012 08:13 AM in reply to: Mark.Downes
In the pattern dialog box. If you hit the rectangular botton you can select the alignment in both directions.
IV2012 Product Design Suite
Windows XP Professional 32 Bit
*Pro
jletcher
Message 15 of 15 (102 Views)
09-11-2012 08:44 AM in reply to: pbrooke
What.
I think you may be lost...
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
