Inventor Forum
Assembly Property in an idw
12 REPLIES 12
Message 1 of 13
AvvyD
1213 Views, 12 Replies
I want to create Leader Text that has a few assembly properties.
Whenever I try this, the leader displays the properties of the part, not the assembly.
If the note has no leader, it doesn't display any property.
If I add a property to the title block, it shows up just fine, but that isn't what I want.
I feel that this should be really easy, but I'm just not seeing how to do this.
I'm using IV 2014.
12 REPLIES 12
Message 2 of 13
Cadmanto
in reply to: AvvyD
Welcome to the forum.
When you are placing your note, which type are you selecting?  Should ne the model properties.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 13
AvvyD
in reply to: Cadmanto
That is what I am selecting.
Message 4 of 13
Cadmanto
in reply to: AvvyD
Ok, and after you select the correct property from the property drop down you are selecting this button to populate the text with this property?
Best Regards,
Scott McFadden
Message 5 of 13
AvvyD
Yes.
And it populates with part properties, not assembly properties.  Whatever component the leader is attached to is what is related to the note.  I want it to bring up the assembly information, not the information from a part within the assembly.
Message 6 of 13
mdavis22569
in reply to: AvvyD
The problem is the assembly is set to break down to the part level if he uses it ... He could make a custom one that populates with the name of the assembly and then pick the custom property
Mike Davis
Message 7 of 13
swalton
in reply to: AvvyD
I don't think that Leader Text can access assembly or sub-assembly properties.  There is an Idea Station request to change that behavior.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Improve-Leader-Text-to-Pull-Subassembly-iProperti...
You might give a kudos to this and help move it up the developer's priority list.
You might add a comment there that references this thread too.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 8 of 13
brendan.henderson
in reply to: AvvyD
What assembly properties are you trying to bring through?
As the others have said you can't use a leader for this. But you may be able to use a sketched symbol to acheive your goal.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 9 of 13
I think this could be done via a custom Iprop that is then set in the leader Mike
Mike Davis
Message 10 of 13
AvvyD
in reply to: mdavis22569
Thank you Brendan, I don't think that would work in this situation.
I want my notes to show project iproperties, like stock number, vendor and so on.
Thank you Swalton, I bumped it!
michaeldavis7418, I made a rule that drove some paramaters I just created.  It allows me to put them in my note, and they'll update automatically.  Is this what you meant, or is there an easier way?
Message 11 of 13
AvvyD
in reply to: AvvyD
So, the rule I created allows me to note assembly parameters doesn't work as intended.
If more than one configuration of the assembly is on a print, the note will read the same for all configurations.
ie,
Part_Number =iProperties.Value("Project", "Part Number")
every assembly that shows "Part_Number" that is from the same parent file has the same information, even if the data table reads otherwise...
Suggestions?
Message 12 of 13
AvvyD
in reply to: AvvyD
and now it's half working...
Message 13 of 13
Jefkee
in reply to: AvvyD
I was looking for the same thing.
What i did was make a new balloon style that shows the DESCRIPTION instead of ITEM NR.
Keep inmind, when you unfold the partslist to part level, it will show the description of the part.
Works fine for me where i needed it.
Inventor 2013
